TLDR at the end... ! I know how much some of you don't like to read essays
Hello! First of all, many thanks for reading and any help in advance. Longer thorough explanations are welcome.
As the title suggests, I am building myself (and my son) a Legacy WinXP Gaming PC. Sadly I didnt want to go for any fixed year, basically I am just getting any powerful hardware from
around the 2011-2013/14 which has official support for winXP, maybe except the GPUs which I have multiple, some for really demanding games, some for really picky ones which can
have visual bugs with some cards.
Everything so far was a smooth sailing until my dumb ass realized that many of those old 2000-2007 era games had EAX support.. Logically since I am trying to build like a "ultimate"
dedicated winXP machine, I want to take advantage of EAX in its original non-emulated way just as was intended, and from what I was reading so far around the internet the WinXP is
the last one which supports actual "hardware Emu processed EAX" and that I should aim for such a card.
Now see this is the issue for me, I am practically an anti-talent when it comes to dealing with something that has anything to do with sound or sound quality, and so I am now absolutely
confused as to what card I should choose, whether to buy some older one thru ebay or some of those which are still available for purchase in shops.. I was looking over some cards but I
wasnt able to find any extensive information on them, whether its HW accelerated or not, or if it supports all 5 of EAX versions, if it has proper drivers for XP and so on..
Also I should mention that unfortunately the Mboard I chose for this setup doesnt have any of those old "PCI" slots which are required for older sound cards, it only has additional
PCI-E x1 slots however I have now for a long time a working PCI-E x1 to PCI Adapter which does seem to be working from a quick test I made, and if it wont I guess I ll just get some
other Mboard which would have original PCI slot.
So I am clueless.. I ve been looking over some of these most popular cards, first the easily available cards like Audigy RX, which has PCI-E x1, but I dont know if it would work with all EAX
versions, I am not even sure if its hardware processed sound, then I was looking over this red one, the "Sound Blaster Z" card, its PCI-E but then again no idea if its HW processed and if
it supports all EAX versions. Then I was also looking over some of those less avaiable cards, esp. the pretty expensive "X-FI Titanium HD", has PCI-E too, from what I read I think it is HW
process. sound and supports all EAX versions but then again theres the high cost and I dont want to blow 150-200 bucks more if I wouldnt have to..
So what do you think,.. What card should I get? Is it right I should aim for actual hardware processed card since I use winXP? Do all of the above mentioned cards support all versions of
EAX? What card do you think that would suit this build best?
Again thanks to anyone who would try to help and please dont post any dumb comments like "WinXp bad, EAX not worth it" etc, I want to have it because it was a supported feature back
in the day, regardless of if it sucks or not, I am aware of it not being that great in some cases..
TLDR: Building WinXP Legacy Pc for Gaming --- I'll take anything powerful that is winXp supported and works as intended and desired --- Want Sound Card for EAX v1,2,3,4,5, ---
Since its WinXP, I read to get HW Accelerated Card is this right? --- Have PCI-E x1 on MBoard but I also have a working "PCI-E x1 to PCI Adapter or I'll swap Mboard if necessary" ---
Was looking over "X-FI Titanium HD", "Blaster Z", "Audigy RX" is any of these suitable? --- Thanks in advance
