Question Aorus z390 xtreme fan controller has stopped me from changing Corsair sp 120 pro fans colours.
Jul 14, 2020
Hey guys I have been through so much struggle the past 6 months. During the setup of my pc I used the default fanhub supplied with the aorus z390 xtreme motherboard. After using fusion 2.0 I have never been able to change or alter my fans rgb colours. I purchased the commander pro along with the 6 rgb fan hub and the fans refuse to change colour. I have updated all drivers on all icue softwares and fusion softwares, removed all softwares and reinstalled and even full wiped the pc and did a complete reset and the fans still won't change. Any help would be greatly appreciated. I am using sp 120 pro rgb fans by corsair.
This seems to be a issue across some forums but have you:
Are the fans plugged in to ports 1-2-3? (No skipping allowed!)
Also double check the USB connection and try a different USB internal port if you have one.
Also this might help but you probably have seen it:
View: https://imgur.com/bEM6Twi
https://pcpartpicker.com/forums/topic/266131-commander-pro-sp-120-rgb-help
I have done all these steps and still the same issue can't get the fans to change what so ever im so confused at this point.
