I have asked a few places, and I haven't been able to get a good fix. I thank you in advance if you're able to help.
After the initial setup, I used the headset for a few minutes before it would start disconnecting and reconnecting, along with these horrible crackling sounds that would appear with each connect. I'm using the USB-C to USB-A adapter, as my pc does not a USB-C port.
I have the Steelseries Engine app and I think changing the dynamic compression slider had started the problem, but I've turned it off and it's still having these problems. The connection is literally half a metre away from my PC, I've tried all the USB ports, and even on my iPad Pro.
On my iPad Pro, with a USB-C connection it seems to work, but on PC these problems return. I've added a few videos with the link to demonstrate with and without music playing.
View: https://imgur.com/a/tyPCl0P
A few clips of the problem.
I've also tested this on my Chromebook both with and without the adapter, and it works fine. I don't want to refund due to this, as it seems to be an issue with maybe drivers or software, and I've ordered a replacement adapter just in case.
