I've got two of these:
on the packaging they give a warning:
“To avoid system instability and possible data loss Do Not attach these magnetic LED strips directly to DRAM, SSD's or HDD's”
I've only seen this after I bought them, otherwise I would have gone for the non magnetic kind and used glue, although it is kind of obvious, I just didn't think 😳 Here was my original plan of positioning:
^theoretical LED strip positions marked by white rectangles
with one on the side of the HDD caddy shinning straight out of the case through the fans (left), and the other pointing out of the holes on the front (right)
It says on the warning not to attach them “directly” to a HDD so I think the one on the front of the case will probably be OK because it will be a little over ½'' below the position of the drives? but the one inside will only be separated from the HDD by the thin caddy metal, I don't think that will be enough?
Because I have no idea how susceptible HDD's actually are to magnetic damage I'm still not sure, any advice would be welcome
System specs here: https://forums.tomshardware.com/threads/build-log-sleeper-pc-with-raid-1-array.3681817/
