Question ARGB 5v fans not lighting!
Nov 15, 2024
Hey All! I am struggling to get my Sama rgb case fans to light up in Amoury Crate. I have 6 3-pin fans, 3 from the case, and 3 bought separately, both of which came with fan hubs for the rgb. I have a asus prime b650 plus motherboard. The fans blow just fine. The cpu fan has a daisy chain that WILL light up the argb fan. Armoury crate will only recognize the cpu fan as an LED strip and even when I click scan for updates, it won’t recognize any of my fan hubs. I ended up buying a cheap argb fan hub from amazon and it still wont load up. Updated drivers and everything. What else can I try? This is a budget build.
6 3-pin fans, 3 from the case, and 3 bought separately, both of which came with fan hubs for the rgb...
asus prime b650 plus motherboard...
won’t recognize any of my fan hubs..
where exactly have you connected these LED hubs to the motherboard?
include link to the case manufacturer's product page,
link to the fan manufacturer's product page showing the included hub,
and link to the separate hub that you've purchased manufacturer's product page.
I have just the 8 port hub I bought separately plugged into the ADD_GEN 2_1 on my mobo. Here are the amazon links to the case, fans, and hub.
SAMA BLW 3 in 1 ARGB PC Case Fans... https://www.amazon.com/dp/B0CB31JKCS?ref=ppx_pop_mob_ap_share
SAMA 3509 ATX Mid Tower Computer... https://www.amazon.com/dp/B0CKRCL1RW?ref=ppx_pop_mob_ap_share
ICOLER ARGB and PWM Fan HUB,8... https://www.amazon.com/dp/B0D7SKBTW1?ref=ppx_pop_mob_ap_share
asus prime b650 plus motherboard...won’t recognize any of my fan hubs
what aRGB header is the CPU fan using?
if each individual hub isn't connected to a motherboard's compatible header(3pin aRGB or 4pin RGB) then they can not be detected by the software.
if still aren't recognized even though you have verified they are connected correctly, they may just be some incompatible devices, or some cheapo stuff that doesn't work.
include the actual manufacturer product page links,
seller links don't help.
