I just got a new case and it has 4 ARGB fans and their controller. The case is MS Titan Pro 2. And I got a new amd wraith rgb. I conected the cpu cooler to the "amd rgb" conector on the top right of the mobo. The ARGB to the down left argb conector and the power to the rgb header. They are working but i cant menage to change the color or the speed. I have a B450 Steel legends and have installed Asrock sync i dont know how its called but it isnt working or is changing the part of the mobo rgb. On the bios i can change the color with rgb but when I put a different speed profile or custom it doesnt change. I have tried to install programs for fan speed or argb controllers with no success so I figured maybe somebody had the same problem. With the amd wraith it could be that it isnt conected to the usb on the mobo but i didnt check for now.
Oh yea I red its something for amd but they randomly just spike up the rpm. The "solution" is to configure a less aggresive fan curv but i cant do that
