Anyone know why I can reach much higher Bclks using the Asrock OC Tuner than
via the BIOS? With all other settings the same (VTT 1.429, PLL 1.853, PCH 1.1), I
can reach 214 Bclk using the OC Tuner, but only up to 198 doing the same thing
via the BIOS. In each case, I'm testing via (for the moment) 10 minutes of Prime95.
I expect I could reach more than 214 via the OC Tuner if I increased VTT, but 214
is plenty. Just wierd that I can't even get a POST if I use the BIOS to set the same Bclk.
CPU multi is just 12 atm as I'm only at the stage of finding the max Bclk. Vcore is
less than 1V (Auto). The usual stuff disabled (Vdroop, SpeedStep, CStates, etc.)
System is an Asrock P55 Deluxe, i7 860, U120E Rev B, 4GB GSkill Ripjaw DDR3/2000,
WD VR 150GB 10K, two SFF12Fs for case cooling, Sycthe Kaze-Jyuni 1900rpm for
the U120E, two ASUS 8800GT SLI, Thermaltake Toughpower 750W, running XP Pro SP3
32bit with Autopatcher.
Ian.
Ian.
