Hello guys,
Got a weird one for you.
So, in a nutshell, my PC has the following fan setup:
Some time ago this happened and I remember downloading Armoury Create and at that time just by clicking silent profile the Chassis fans went quiet.
However, as the above happened some time ago, I forgot about Armoury and just started to Google for how to control non-software able fans, so I saw the BIOS tinkering threads and stumbled upon a thread citing the AI Suite 3 program, so I downloaded it, clicked on the option to optimize fans, then silent profile and bang done, HOWEVER, after optimizing the fans process was done, I now noticed that the Radiator Fans started to be noisy, I looked at the AI monitor and noticed that the "CPU Fans" (which I take are actually the radiator fans as I have an AIO Cooler in place) options where all greyed out so profile and settings tinkering was not possible or aplicable to CPU Fans. Upon doing more research I stumbled upon a thread saying that everything AIO Pump should always be left untouched and that both the BIOS and controlling Software defaults have the AIO working at 100% capacity.
The increased noise from the Radiator Fans is not that disrupting as the Chassis Fans BUT before installing the AI Suite 3 there was no noise coming from those fans and the RPM's (which I always monitor with NZXT) are exactly the same before and after AI Suite 3, namely, 2631rpms. I tried to set a silent profile in BIOS for the CPU Fan and somehow never worked (now I know its because AI Suite 3 was somehow overriding BIOS).
Suddenly I remembered about Armoury and updated the app then when opened I was able to also control the Chasis Fans with the pre-set profiles, but the Radiator fans still were being loud.
So I uninstalled AI Suite 3 and suddenly the Radiator Fans where back to silent, but as mentioned before with the same exact RPM's.
Question here is, anyone know why AI Suite 3 kicked the fans into harcore mode? Is it better for the Radiator Fans to be noisy than quiet (temp and performance-wise)?
Any insights will be greatly appreciated.
- 3X Chassis Fans attached to the front side of the case
- 1x Chassis Fan attached to the back (basically the exhaust fan)
- AIO Radiator Fans on top.
