Question Asus Dual RX 580 4GB stuck at 1025 MHz
Tony1337
112
I recently built a PC with the RX 580 and tried to test it out in Heaven and realized it was stuck at 1025 MHz. Trying to change the clock speed in Afterburner or Wattman did nothing after I hit apply.
Provide full PC specs. What's the make/model number of your POWER SUPPLY unit/PSU ?
Please supply the following system details/information:
(Complete System Specs)
-CPU make and model# (clock speed/voltage, type of cooler, and "Core" temperature @ idle and load)
-Motherboard make & model# (include Bios version if graphics card is not recognized or you are having stability issues)
-RAM (amount, clock speed, model#/link of kit, configuration)
-Graphics card(s) make and model# (clock speed, voltage if modified, Driver version and GPU temp both @ idle and load)
-Power supply make,model#, "AND" age (note if using 110V or 220V A/C input)
-HDD/SSD configuration (ie: Raid setup/ back up/ OS drive/etc..)
-Case/Chasis make,model# (fan make, model#, and configuration if having thermal issues)
-Operating System (If using Windows note Framework and service pack version)
-Monitor make, model#, and resolution (If model# is unknown list resolution and refresh rate)
