Hey everyone. Seems like everytime I have a question google points me to this forum. I’ve searched everywhere and cannot find my answer. I have an Asus M32CD-AS51 [VivoPC Tower]. Motherboard number is in the picture. My front hub has 2 USBs that don’t work. I’ve done USB hub uninstall and reinstall for the driver updates. I’ve done all the other testing for allowing the BIOS to use them. Done a lot of testing and still nothing. All the rear USBs work. The audio and mic port on the front hub also works. I don’t know if Power is coming out of the motherboard at the 4 pin usb power header. If I knew how to test that I would, any help would be appreciated.
I figured I could try to find the correct SATA routing because maybe that would affect them too. I have the AAFP and USB-PWR1 headers installed. I do know that SATA 6G _1 is for my boot drive SSD and 6G_2 is for my HHD. 6G_3 would be for my DVD drive? And I would imagine the USB2_1/2 and USB 3_1/2 would be attached to my front hub, but have no idea how the SATA port colors of the motherboard and the colors of the front hub match(if they are supposed to) or how the SATAs are supposed to be connected. If I can’t figured it out or the front hub is indeed bad, I’ll just install a mini PCIEx1 to USB3.0 adapter and run them out the back. Thanks to anyone who can help! I also don’t know what the white 5 pin connector is..
![nWHk9Xl.jpg](https://i.imgur.com/nWHk9Xl.jpg)
![xU48jw8.jpg](https://i.imgur.com/xU48jw8.jpg)
