Question Audio and visual stuttering on new PC build ?
Pinz
56
I just built a new PC with the following specs. https://pcpartpicker.com/list/mPjyZJ
At first everything seemed fine, but for the past two or three days I've noticed when I'm playing a game (anything from Bloons TD6 to Baldur's Gate 3) and I have a browser video playing, or I'm in a discord call, I get audio and visual stuttering. They are in sync so when I hear an audio stutter there is a visual stutter for the exact same amount of time. I have hardware acceleration turned off on my browser, which is Firefox, as well as turned off on Discord.
I'm at a loss because my system should be able to easily run these games and have a simple video or discord call running on my second monitor. I'm new to building PCs so I'm afraid I messed something up or forgot something important. If there is any other information I need to provide please let me know and I will do my best. Thank you for any help in advance!
Have you done a clean install of your OS or did you copy it off of somewhere?
Go into your BIOS and reset all settings to defaults.
Try using DDU to clean-install your Graphics Drivers.
Im not sure what a clean install entails. I made a USB drive into a installation tool using Windows tool creation program.
I will try doing that as well as updating my BIOS because i think there's an update available.
I haven't used DDU in ages since I remember reading it shouldn't matter but at this point i'm willing to try anything.
Updating the BIOS seems like a good idea, make sure your PC doesnt lose power during the process.
It'd be worthwhile running LatencyMon while you're doing some of these things just to see if it's potentially some sort of driver/software conflict causing the issue. The system itself is certainly plenty powerful for what you're trying to do.
