Hello, I am going to get a Gigabyte aorus B550i pro ax and was wondering if it had any argb/rgb headers to power the lights on some of my fans as well as my aio lights. The liquid cooler is the MSI mag core liquid 240R- AIO RGB. And the fans I will be using Are EZDIY-FAB moonlight 120mm rgb case fans 5 pack.
links to these items are as follows:
Motherboard: GIGABYTE B550I AORUS PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) https://www.amazon.com/dp/B089FWWN62/ref=cm_sw_r_cp_api_fabc_g5fXFbGTPP5XB
Liquid cooler: MSI MAG CORELIQUID 240R - AIO RGB CPU Liquid Cooler - Rotating Cap Design - 240mm Radiator - Dual 120mm RGB PWM Fans. https://www.amazon.com/dp/B087YXWFTK/ref=cm_sw_r_cp_api_fabc_D5fXFb9980MCD?_encoding=UTF8&psc=1
Case fans: EZDIY-FAB Moonlight 120mm RGB Case Fan with 10-Port Fan Hub X and Remote,Motherboard Aura SYNC,Speed Control,Addressable Fan for PC Case-6 Pack https://www.amazon.com/dp/B07XBSKTY6/ref=cm_sw_r_cp_api_fabc_.3fXFbBMEWBR9
