Hello guys, I need some help picking components, especially with the motherboard. Budget arround ~220$ or 200€.
I’m trying to build a balanced PC that is good for gaming. If I do OC it would be a very small OC. I’ll reuse some components from my old rigg for now:
PCPartPicker Part List In dollars buying in US
PCPartPicker Part List In euros buying from Spain (same thing but buying in Spain)
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor ($539.98 @ Amazon)
CPU Cooler: Noctua NH-U14S 82.52 CFM CPU Cooler ($63.75 @ Amazon)
Motherboard: MSI MPG B550 GAMING EDGE WIFI ATX AM4 Motherboard ($189.99 @ Amazon) It's just an example, should change
Memory: G.Skill Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($134.99 @ Newegg)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive ($99.99 @ Amazon) , also older SSD and 2 Sata HDDs.
Video Card: EVGA GeForce RTX 3080 10 GB XC3 BLACK GAMING Video Card ($779.99 @ Adorama) I will buy it latter.
Case: NZXT H510 ATX Mid Tower Case ($69.99 @ B&H) It's just an example, should change
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply I'll try to reuse mine.
Total: $1878.68
Generated by PCPartPicker 2021-01-25 13:53 EST-0500
Thanks for reading this far
. If you can share some knowledge or advice It would be much appreciated.
- Crossair RM 750W Gold plus (2014 version).
- 980 graphic card Asus GeForce Strix GTX 980 DirectCU II OC 4GB GDDR5. However I will swap this with a 3080 GTX as soon as I can find one at decent price.
- They say some AM4 mobos doesn't work with 5800X unless you update them but obviously you need an older ryzen to do that. Soooo, What should I search in the specs of the mobo to be sure is more or less modern and do not require updates to work with this CPU?, all B550 have same problem and I need to go x570?. Original message: Some AMD B550 chipset motherboards may need a BIOS update prior to using Vermeer CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions.
- I search in the mb that it has: newest bluetooth, as good as posible ethernet, could have, acceptable sound, compatible with old and new graphic card (GTX 980 and 3080 RTX)
- What should I look for to make sure it is compatible with M.2 hardrives to use as main HDD with the OS? I'll use one M.2, one SSD and 2 normal SATA HDDs.
- I do not care about SLI/Crossfire. Minimum OC is more than enough.
- ¿Any recommendations in what should I look for? (I'm not an ASUS fan had horrible experience with their customer service)
Total: $1878.68
![Smile :) :)](/data/assets/smilies/smile.gif)
