Best card for 1024 768 res.
Page 7 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
aasifdm
118
hi everyone pls suggest me best graphics card for 1024 768 res for my crt monitor i will play games at this res only. and the card should be powerful one so i can play all the future newer games at the same res. i will buy a good power supply and a cpu for it. i havin a m2n sli deluxe board and 3 gb ram.
the card should be a good performance and powerful for the future games.my res would be the same at 1024 768. appreciations.
The Phenom series is worse that the Athlon II series. You will want a Phenom II x4-x6 for gaming. For low-med gaming, x2-x3 is good. If I were you, I would get an hd6850 is you want to play new games, and future games all maxed out with that res. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127566&cm_re=hd6850-_-14-127-566-_-Product good card right there. PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341039&cm_re=OCZ_600w-_-17-341-039-_-Product I own that PSU and it is good. OCZ makes pretty solid PSUs and it is 600w. I heard that it can go 700w, but I wouldn't test it.
What O.C.ing is about: Making your PC run faster at a small risk if you know what yiu are doing. I am kinda of a novice too, but I can still OC just fine. It's is really easy for an AMD CPU. A little harder for an Intel. Basically, you go into the BIOS and you have what is called the multiplier and the Front Side Bus. (FSB) With a non-black edition CPU you cannot mess around with the multiplier unless you want to downclock your CPU and save power. So in your case, you would adjust the FSP (say 220Mhz) and get 3.3Ghz! Amazing, right? Now that is a very minor OC and you will not need to adjust anything else probably. When OCing with 800Mhz RAM, like I suggested for you, turn it down to around 667Mhz. (A lttile slower, but you will get it back to 800Mhz) You might even need to bump up the voltage on the RAM and CPU. If I were you, I would shoot for 3.5Ghz. Here is what you should do: RAM voltage: 2.1v CPU voltage: +3.3% CPU frequency/FSB: 235Mhz RAM speed: 667Mhz HT link speed: x4. That will give you 3.5Ghz, 940Mhz HT link, around 800Mhz RAM speed, and a very small CPU voltage change and RAM voltage change. Download OCCT and Memtest 86+. OCCT will stress your CPU, board and memory, and Memtest 86+ will stress your memory and tell you if it works.
No, keep the same multiplier and up the timings of the CPU, not the RAM. You can put down the multiplier for energy saving stuff and keep the same CPU clocks, but that's the opposite of O.C.ing.
Yes, that is what I am saying: because it will turn the RAM speed up to higher than it should, you turn the RAM down to say 667Mhz and let the FSB bring it back up to 800Mhz. That is what I did. I do not have a BE.
Yes, it will bring it back to 800Mhz. With a non-black edition CPU you can only make the multiplier go down, resulting in a DC which is the exact opposite.
NO NO NO! You are on the wrong track buddy..... The hd6850 is better than the hd5670, but at your resolution, you don't need a great card, that is why he suggested the hd5670. You want to be future-proof and play games maxed out, right? It is not about a better card being worse, some cards are just better, but you do not need all that power. In this case, you do not need more than a hd5770, FOR NOW! Later, when DX11 games (which the hd5xxx series suck with) you will be more future-proof with the hd6850. I suggest the hd6850 knowing that you will not be disappointed at all. Apparently you do not know that some cards are just plain better than others, period. At least, that is what it sounds like. The hd6850 blows the hd5670, and the hd5770 away, in like any game. That means that it is a better GPU. right now, a hd5770 would be fine for you, but later, you will need more power like a hd6850. GET AN AMD HD6850, AMD ATHLON II X4 3.0GHZ, AND 4GB 800MHZ RAM! After that, you will be set, despite people saying you don't need it, you will, LATER. Tell me what you think.
