Best card for 1024 768 res.
Page 6 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
aasifdm
118
hi everyone pls suggest me best graphics card for 1024 768 res for my crt monitor i will play games at this res only. and the card should be powerful one so i can play all the future newer games at the same res. i will buy a good power supply and a cpu for it. i havin a m2n sli deluxe board and 3 gb ram.
the card should be a good performance and powerful for the future games.my res would be the same at 1024 768. appreciations.
The Phenom series is worse that the Athlon II series. You will want a Phenom II x4-x6 for gaming. For low-med gaming, x2-x3 is good. If I were you, I would get an hd6850 is you want to play new games, and future games all maxed out with that res. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127566&cm_re=hd6850-_-14-127-566-_-Product good card right there. PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341039&cm_re=OCZ_600w-_-17-341-039-_-Product I own that PSU and it is good. OCZ makes pretty solid PSUs and it is 600w. I heard that it can go 700w, but I wouldn't test it.
Yes, get a CPU first, or it will bottleneck. Grab an Athlon II X4 @ 3.1Ghz and a hd6850 and then you should not have bottlenecks and your system shoud run pretty strong. By the way, I think you wanted 2gb more RAM, right. What is speed, brand, CAS, and name of the module of RAM you have now. I can help you pick some out.
Well, I mean, it will only probably burn down your house, then Russia would nuke Chine, the UK would nuke Russia, America would nuke the UK, and then the whole entire world would explode by a asteroid shower.... Besides that, nope, nothing would happen.... JUST KIDDING!!!!!!! Yeah, as long as you have a PCI-E slot you should be fine. So, get two more gigs of RAM, one hd6850, and a Athlon II X4 @ 3.1Ghz and you would be set.
are you still talking about 1024x768 ? If yes then i think HD 6850 is not necessery.
is the only difference between phenom II 9xx and 8xx l3 cache?
OFF TOPIC : Your PC won't burn down if you have a cooler with holy water!
