Hi, a few days ago I accidentally spilled water literally on my running PC, lateral case was taken off because reasons(never bothered to put it back) easier to clean PC and inspect it from time to time, PC was on and like half a glass on sparkling water fell right on the GPU, monitor went off 1 second, second 2 turned off pc but made up my mind didn’t even try to check on it, I know it’s done.
I was looking everywhere for a budget desktop, somewhere around 800-850€ (850-900$) found a few but not satisfied enough because either case too small, cheap components, weak psu’s, at this price it’s quite hard to find something good. I found Acer 50 Nitro but only with Intel and I would dearly prefer Ryzen. Now, I want to you if possible to tell me the best motherboard and case options for a ryzen 5 5600X paired with a gtx 1650. I had 1050Ti before and I think 1650 it’s a good enough update since they both still go by the same price since I’m not really into hardcore gaming, ryzen 5 5600X is a must. Please let me know your opinion and many, many thanks.
I wanted to order this
Sistem Gaming Lenovo IdeaCentre 5 14ACN6 AMD Ryzen™ 5 5600G 4.40 GHz, 16GB DDR4, 512GB SSD M.2 2280 PCIe NVMe, NVIDIA GeForce GTX 1650 SUPER 4GB GDDR6, No OS but I checked an unboxing on youtube and the moment I saw the motherboard I knew it’s a no,no.
This also looks really good ( for me) but Intel
Desktop Gaming ACER Nitro 50, Intel Core i5-11400F 4.4GHz, 16GB, SSD 512GB, NVIDIA GeForce GTX 1650 4GB, Free Dos.
If I get something I would like to upgrade it at some point and the Lenovo one it’s impossible and the Acer one has intel and unless someone changes my mind to “betray” amd, I wouldn’t go for it.
