After researching a bit issue is i cant upgrade my bios on win 7 64 bit
Hi,
I realize it has been a while since you asked.
However, I just wanted to tell you you can update the BIOS on this board through a usb boot disk. Easiest is with Rufus
https://rufus.ie/
After you create the disk download the latest Bios update which is F6e from Gigabyte
http://download.gigabyte.us/FileList/BIOS/motherboard_bios_ga-g31m-s2c_f6e.exe
It is a autoextract zip file. You can run it on any PC and it will extract 3 files:
autoexec.bat
FLASHSPI.EXE
G31MS2C.F6e
The autoexec has one line: flashspi G31MS2C.F6e
Copy FLASHSPI.EXE and G31MS2C.F6e to the boot disk
copy autoexec.bat as well , replacing the one rufus created. Alternatively you can edit the rufus autoexec by adding flashspi G31MS2C.F6e at the end of the file (right click the rufus autoexec.bat >edit , paste the line, save and close)
Now your boot disk is ready. place it in a USB port and restart the PC. Press F12 repeatdely until the boot menu comes up, scroll down with the downward arrow on your keyboard to "+Hard Drive" and press Enter. You will see a list of all hard drives on your PC as well as the USB drive (such as Kingston USB, Sandisc USB etc.) Choose it and hit enter. This will run Freedos followed by Keyboard layout selectio. It doesn't matter what you choose because the flash program will run automatically and flash the BIOS.
None of your BIOS definitions will change. You can boot normally to Windows.
Now that yoh have the latest BIOS, you can decide which CPU to buy from the support list:
https://www.gigabyte.com/Motherboard/GA-G31M-S2C-rev-1x#support-cpu
You can go upto a Core™ 2 Extreme QX9770 , but these sell for around 200$ on ebay....
You will do fine with a much cheaper Core™ 2 Duo E8600 3.3 GHZ which sells for 7$ or Core™ 2 Quad Q6700 for 15$
I would go with the E8600.
BTW, you can still upgrade for free to Windows 10 using the Microsoft Media creation tool. I did that on this board. All the drivers were found during installation.
I still don't think you can play new games on this rig because of the limited 4GB RAM that the board supports.
Good luck!
