Question Best Graphics Card for $130-$150 range
watrhous
319
14
I am lookign for opinions on a graphic card for around $130-$150 range for light gaming and mostly photoshop. 8gb perferably. I am pairing with:
Ryzen 5 3600
MSI MPG x570 gaming edge wifi
and 32gb ddr4 3200 ram
Suggestions?
watrhous
319
14
what is your major usage?
budget and country?
You usually consider the build on a whole :)
The use is mostly for photoshop cc.
Budget is $130-$150 and my country is USA.
The primary budget is $1050.
Is there something wrong with the mobo? You got me worrided now :)... The build requires lots of RAM for photoshop, the CPU is 12 threads which Photoshop can not use more than, The motherboard is intended to be upgradeable and the graphics card just needs to be 8gb (preferred) and $130-$150 range. If you see some kind of problem with the build i would certainly appreciate your advice.
otherwise, do you knwo a gfx card thats in the $130-$150 range with 8gb of ram and reliable? All the reviews i read talk about them burning up on fire and frying everything ...
Before you had replied i kinda settled on this card but I am certainly willing to change it out at your advice.
XFX Radeon RX 570 RS XXX Edition 1286MHz, 8gb GDDR5, DX12 VR Ready, Dual BIOS, 3xDP HDMI DVI, AMD Graphics Card (RX-570P8DFD6)
You don't need a 1k pc or gpu just for PS. An IGPU can do the trick already. This will be fine for PS unless you have unusual requirements. Do you do very large picture? What is the size?
PCPartPicker Part List
CPU: AMD Ryzen 5 3400G 3.7 GHz Quad-Core Processor ($139.89 @ OutletPC)
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard ($74.99 @ Amazon)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory ($64.99 @ Newegg)
Storage: Crucial MX500 500 GB 2.5" Solid State Drive ($64.50 @ Amazon)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($94.89 @ OutletPC)
Case: Fractal Design Focus G Mini MicroATX Mini Tower Case ($54.99 @ Amazon)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply ($59.99 @ Newegg)
Total: $554.24
Generated by PCPartPicker 2019-09-12 09:07 EDT-0400
watrhous
319
14
Total: $554.24
Large hi res images for graphic design work. And the guy im building for wants the price point and hardware where it is.
