Best Graphics Cards for my PC systems
knightoii
6
so, my gtx460 SE nvidia went kaput after 2 years, although i'm a gamer but i'm a newbie in computer hardware and stuff, my question is, what is the best gaming graphic card suits my pc systems best without creating bottle neck effect, my pc spec as below:
Windows 7
Intel quad core i5-2320 3.0 GHz
Resolution: 1920X 1080
Ram: 4Gb
Power Supply: 600watt
Asus Mobo (didnt know the model)
Please advice what is the best gaming graphic card i can get, thanks in advance!!
Wont be bottlenecked by your system at all and you will likely be very happy with the product if you choose the right aftermarket cooling solution :) asus, msi, and zotac all make fairly good cards
knightoii
6
Appreciate your time to answer my question, gonna take a look to see if it fits my mobo lol.
I'd almost be willing to put money that you will have no compatability issues as the sandy bridge cpu you have is new enough to have pci 16x slots on the mobo, and that is what the 650 ti is compatable wit, and the card can be found in configurations that arent that big if you have a smaller case
knightoii
6
