Well, yesterday my uncle gave me his old pc, its a celeron 500Mhz, 384Mb PC-100, 80GB WD IDE and a PcCHips M755LMRE mobo
the problem is that when you shut down the computer, all bios settings are lost
If you shut it down and then turn it on in less than a couple of minutes, the settings are not lost, but if you wait a little longer, you'll have to reconfigure everything again
I have already replaced the battery and also checked if the CLEAR_CMOS jumper was in the erase position, but nope, it's in the correct position :S
I've searched all over the net but I can't seem to find anything about the M755LMRE model, but M755LMR model...there are 2 versions, 5.x and 7,x and for what I saw, mine is 5.7
The version number is printed on the corner of the mobo where the keyboard connector is, that's where I got it
So, what could be causing the problem?
note: everest reports it as a LMRE, but apparently there's no such mainboard (or all traces of it where destroyed by the FBI/CIA/KGB), and IF it were an LMR then it would be v 5.7 as stated
