G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I've been looking through old posts and it seems like a lot of BHs have
similar problems.
I have a loud hum, normal volume speech, and barely audible sounds.
Hum varies with the main sound pot behind the coin door. I've adjusted
the sound and speech pots on the sound board (R15 & R16) to balance
them out, but turning up the sound pot (and ONLY the sound pot) causes
more or less hum.
Now, I know by earlier posts and google searches that there are several
things to check. In general - proper grounding, board connections, the
big caps in the cab, speaker connection, the speaker itself.
Something I did not find in past posts was what does it mean when it's
the SOUND side only where most of the hum is being introduced? Speech
by itself (like in attract mode) is pretty clear of hum.
Looking at the schematics I see several capacitors in the audio
circuits, particularly C31 on the sound line and C32 on the speech
line. If I understand the schematic properly, these are the only two
caps which are line specific. Knowing that a bad filtering cap is one
cause of hum, that the hum is very evident in sounds but not in speech,
I'm thinking replacing C31 should be the first thing to try, since
everything else that can cause hum would cause it equally to both sound
and speech.
Is my thinking way off base? Thanks, Q
similar problems.
more or less hum.
and speech.
