The GAMING model would be a much better option..
It's your choice, if you prefer a blower style cooling, or a single/dual/triple fan design for the PCB (Open Air) ? But these reference blower type GPUs can get noisy under load though. It also depends on what type of ATX cabinet you are having.
The blower cooler will help push the hot air from the near of the chassis. It sucks air in through the single fan in the front of the card and blows it out of the back. It is important to note that even though all blower-type coolers use a single-fan design, not all single-fan cards are blower-style.
Exhausting air out the back of the card helps in cases with poor airflow since there is no hot air blown into the case; conversely...
