[SOLVED] Blue Screen Of Death due to overclock speed?
Jul 8, 2020
I bought this Acer Laptop a year ago. But it got some issues since I brought it and haven't been solved till now. I experience a lot of Blue Screen of Death if I start using heavy software like Adobe Premiere Pro , photoshop or any other game. I have not over clocked cpu of this laptop as there is no option in the BIOS. Well, the problem behind the scene would be the GHz the processor is using. As my baseband speed is 2.7 GHz but this system runs at 3.01 GHz most of time causing overheat issue and Blue Screen of Death. I have done all the recommended things like formatting the OS, changing the OS, updating drivers. So, if anyone is familiar with the similar type of problem, do help me.
Laptop Model: Acer E5-575G-53VG
Processor: i57200U
Ram: 8GB
Graphics Card: Nvidia GeForce 940 MX
SSD: 256 GB
Image of CPU Performance.
https://drive.google.com/file/d/1VEXYzWtCBkH5AJETFSDRELDFgslwVPfj/view?usp=sharing
Dump Files:
https://drive.google.com/drive/folders/1Jwml457Ohum-HDnS1dgrTAG5mytX4DXJ?usp=sharing
i would recommend to check the ram.
for this, you just need a usb key, then install an utility on the usb key and boot from the USB.
you can download the auto installer here : https://www.memtest.org/download/5.31b/memtest86+-5.31b.usb.installer.zip
(it will format the usb key, all data will be deleted)
let the utility run for about 24hrs. if you see red stuff, it's mean the problem comes from he RAM
If you want to limit the frequency of your CPU easily on a laptop on windows,
go to control panel -> the power plan (usually it's balanced or normal) , clic on advanced settings, on the bottom you'll see "maximal sate of the CPU : 100%
dial it down to like 90%.
I do this all the time on laptops so they get silent.
