Bluetooth audio
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Does anyone know how integrate a bluetooth Motorola HS850 (Wireless
headset)with a desktop running XP Pro. I do have a D-Link USB Bluetooth
Adapter (DBT-120) attached to my computer.
The Bluetooth device manager did find my headset and said that it is working
properly but I can't seem to be able to use it.
Any help would be greatly appreciated.
Pierre
Go to HKLM\SYSTEM\CurrentControlSet\Control\Class\. Delete the following key: {e0cbf06c-cd8b-4647-bb8a-263b43f0f974}. Open Device
Manager. (run devmgmt.msc) Remove the Bluetooth listed here. Click Action, click Scan for hardware changes. This should
re-enumerate the Bluetooth adapter, using the SP2 drivers.
Mark L. Ferguson
FAQ for MS Antispyware version 1.0.509
http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
marfers notes for windows xp http://www.geocities.com/marfer_mvp/chatNotes.htm
"n0mercy" <n0mercy@discussions.microsoft.com> wrote in message news:A8BD875D-C90B-4E26-B87E-7DF048119801@microsoft.com...
> Pierre
Pierre did you have any luck with your bluetooth headset. i have exactly the
same problem.i managed to get to the part to delete bluetooth but found there
are 4 types of bluetooth not being very computer literate did not know which
to delete.did it work for you if so can you advise me )in simple terms) many
> Pierre
Sorry GEMMA, no luck, I can't wait 'till I find how it is possible.
> > Pierre
thanks will you let me know if you do get the answer. i have spoken to a few
people who say they have heard of people using this method. so if i get the
answer will let you know
> > > Pierre
HI PIEERE
BLUETOOTH HEADSET. I HAVE MANAGED TO PAIR HEADSET WITH COMPUTER.
UNFOTUNATLEY NOT WITH D-LINK.I BORROWED MY FRIENDS USB ADAPTOR A EZURIO ABOUT
£28 FROM SUPPLIER. LOAD DISC SUPPLIED ACTIVATE HEARSET ON THE SCREEN PAIR IN
WITH YOUR HEADSET,WILL SAY CONNECTED PRESS YOUR MULTIPLE CONTROL BUTON ON
YOUR HEADSET AND YOUR THERE. LET ME KNOW IF YOU GET THIS MESSAGE AND IF YOU
ARE SUCSESFULL
> Pierre
