boot problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
a friends computer (Dell) goes to the boot up screen whenever it is turned
on. No matter which choice they make (Safe Mode, Normal, Previous Good) the
computer goes to a Dell screen then immediately returns to the boot up
screen.
Occasionally a blue screen flashes on for about 2 seconds, and I caught the
words "Unmountable boot volume" before the screen disappeared.
I have never seen this before and don't know what to do for them. Can anyone
help me?
Take out the GARBAGE before replying to my address
Which Operating System?
Clark
> screen.
> help me?
Hi,
Boot the system with a WinXP CD or with the boot floppy set and hit 'r' when
prompted to enter the recovery console (you will need the admin password if
there is one). From there, run "chkdsk c: /r" (w/o the quotes) and check the
state of the drive.
Also, if SP2 is installed, when you get to the boot menu, try the option
disabling the automatic restart on system failure. This should generate a
blue screen (stop error) with details as to why it failed. Post back with
this information.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Brian Gotjunk" <briangotjunk@yahooGARBAGE.com> wrote in message
news:eWM4PxOrFHA.1724@TK2MSFTNGP14.phx.gbl...
> the
> screen.
> the
> anyone
> help me?
In case you need them:
HOW TO: Install and Use the Recovery Console in Windows XP [Q307654]
http://support.microsoft.com/?kbid=307654
Using the WinXP Boot floppy set:
http://www.rickrogers.org/fixes.htm#Boot%20floppy
Best of Luck,
"Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
news:OCvem1UrFHA.3068@TK2MSFTNGP14.phx.gbl...
> Hi,
> when prompted to enter the recovery console (you will need the admin
> password if there is one). From there, run "chkdsk c: /r" (w/o the quotes)
> and check the state of the drive.
> this information.
> Best of Luck,
>> the
>> screen.
>> the
>> anyone
>> help me?
news:OIW5vFVrFHA.2924@TK2MSFTNGP10.phx.gbl...
> Best of Luck,
> > Hi,
quotes)
a
with
> > this information.
> > Best of Luck,
turned
> >> the
> >> screen.
> >> the
> >> anyone
> >> help me?
Thanks for this help. They are using SP2, so I will download and create the
6 disk set from my computer, and follow your suggestions. I'll post the
results later.
> Hi,
> this information.
> Best of Luck,
>> the
>> screen.
>> the
>> anyone
>> help me?
Did the chkdsk from the XP cd, and it fixed a problem. Exited out of the
recovery console and the system booted, and is now working.
I did not see an 'automatic restart on system failure' option in the boot
menu that I could disable, but had a blue screen flash by too quickly to
read before I did the chkdsk.
Thanks for your help
Hi,
Glad it's working. That boot option, by the way, only exists if SP2 has been
installed.
Best of Luck,
news:%2372eMKZrFHA.908@tk2msftngp13.phx.gbl...
>> Hi,
>> quotes) and check the state of the drive.
>> this information.
>> Best of Luck,
>>>turned
>>> the
>>> screen.
>>> the
>>> anyone
>>> help me?
news:Oo8MGqcrFHA.1724@TK2MSFTNGP14.phx.gbl...
> Hi,
been
> installed.
> Best of Luck,
> >> Hi,
option
a
with
> >> this information.
> >> Best of Luck,
> >>>turned
Good)
> >>> the
up
> >>> screen.
caught
> >>> the
> >>> anyone
> >>> help me?
boot
It does have SP2, but I didn't reboot after running the chkdsk becasue it
went straight to Windows
> Clark
Since this is an XP newsgroup, I imagine it's an XP OS.
The reader should exercise normal caution and backup the Registry and
data files regularly, and especially before making any changes to their
PC, as well as performing regular virus and spyware scans. I am not
liable for problems or mishaps that occur from the reader using advice
posted here. No warranty, express or implied, is given with the posting
of this message.
