That is going to depend entirely on the size of the clinic. Square footage? Number of floors?
-Wolf sends
Since you have not mentioned size of property, I am not sure how we are meant to know if one AP would be enough, you've given no information.
Buy a Ubiqiti Switch 8port POE that will sort everything and as many AP's you need PoE of course, less cables.
and![]()
UniFi6 Long-Range
High-performance, indoor/outdoor WiFi 6 access point with extended signal range. Features: 5 GHz WiFi 6 band (4x4), 2.4 GHz WiFi 4 band (4x4) 3.0 Gbps aggregate throughput rate Horizontal, downward-tilted antenna pattern to widen coverage area (1) GbE RJ45 port (PoE In) Powered with PoE+...www.ui.com
That should cover most needs and you can add CCTV later on if you wish through PoE
IF you are going to go with Ubiquiti, then a security gateway and a cloud key will make the whole thing much easier to manage. You can setup a VLAN with separate SSID for the guests that will have no access to the office equipment but can have internet access.Since you have not mentioned size of property, I am not sure how we are meant to know if one AP would be enough, you've given no information.
and![]()
UniFi6 Long-Range
Oh Oh sorry its a single storey building, is roughly 350 - 400 Sqm. It has its own server room, would you put the router and switch in there as well?
