Hi everybody,
I have 9900K with Z390 Aorus Master board. I am also equipped with Noctua NH-D15 cooler.
With all the information about the (notorious) MCE setting in the bios, I couldn't find a definite conclusion. I know the majority of people prefer no to use it cause you can just dial a manual overclock to 5ghz with much lower
voltage and get better thermals and less stress on the CPU..etc' etc' But I am one of those who got tired of overclocking and stress testing (did that enough in the past) ..I just want to get my 5ghz and game
So I decided to give MCE a try. Yes..the temps are a little higher than ideal, but it stays well under 90c when gaming (9900k thermal threshold is 100c). The higher I got so far is 95c in Cinebench R20, but this is the most stressful thing I would run on this machine, I am not about to do stress tests of any kind (OCCT, prime etc'). And this is summer reminds you..it is pretty hot where I live.
And the most important thing for me is that the system seems stable and I don't get any WHEA errors in HWinfo.
With my specific board (Z390 Aorus Master) MCE is pushing the 9900k to 5ghz non-stop, full pedal to the metal, It doesn't even clocks down like previous versions of it (as I remember from my previous 8700k+Z370 system).
The Vcore is hanging around 1.38 but it sometimes spikes up to 1.4+ and even reaches 1.45-1.47 every once in a while, but it is only occasionally.
I know that anything up to 1.4 supposed to be ok but those spikes are making me a little worried.
And now for my main question: Assuming I am fine with the temperatures, can I keep using MCE without too much concerns?
Bonus question:
And by the way, do you think I should try the 5ghz Gigabyte's own preset in the bios? As far as I know MCE just unleashes all the current and power limits for the board without touching any other settings, and the board/CPU does whatever it likes. Maybe the 5ghz preset would be better since it is more like overclocking. I would really like to have your opinion on this, any input would be appreciated.
Thx.
Bonus question:
Thx.
