Hello. Basically, I want to add RGB fans to my pc.
I have MSI tomahawk b450 max and it has 4 x 4-pin system fan connectors and 2 x 5050 RGB LED strip 12V connectors.
I want to know if I am able to do add 3 or more RGB fans to this pc with these connectors or do they only support normal fans?
What about the 5050 RGB LED strip 12V connectors? Are they just for led strips or for fans as well?
Also, I've read this mobo doesn't support ARGB. Is there any way I can make this work with these connectors because ARGB has 3-pin connectors and if not what do I need?
I'd appreciate any help. Thank you
