Can i use a netgear wireless card to access belkin wireless access point
They should work fine together assuming you have the correct security type and password entered in the laptop, and the wireless radio type of the card is allowed on the Belkin. An example of a problem would be if it was a G wireless card and the AP is set to N only, otherwise you should be good.
