[SOLVED] Can someone help me with Memory / Voltages UCLK-FCLK
Vana Ivan Pandovski
274
11
18,865
Hi, so I cannot be too much explanatory in the title of course but I want some of you guys that have knowledge on stuff as memory infinity fabric and memory and some voltages why are displaying on this way on this picture https://puu.sh/Ev87n/a5642517d0.png
So first when I open HWiNFO64 there is nothing showing about the Infinity Fabric Clock, it is just the UCLK the Memory controller clock, BUT when I close the program and put my PC to sleep and I wake it just second after and I start the HWiNFO again there it is the FCLK is there? Why is that like that???
Second I have decent power supply Cooler Master B Series 600W v.2 and for some reason, you can see on the image that the 12v rail is showing 11.400v and the 5v rail is showing 3.1volts?
When I check AIDA64 shows this picture https://puu.sh/Ev8ia/13d7c76a00.png and when I check the other tab in AIDA64 shows this image https://puu.sh/Ev8iA/346d4a210d.png
Also, I have this image from the BIOS voltages https://puu.sh/Ev8XI/84c5d53054.jpg are they correct or?
Please can you guys explain to me these things, why the Infinity fabric is been shown after Sleep of the PC, on the HWiNFO64 and what is with the voltages> Am I on the safe side here, or is it something wrong? I have overclocked my CPU Ryzen 5 3600 to a 4.2GHz Stable across all cores, I have done aida64 tests with CPU, FPU, CACHE, and MEMORY all came good, although I am on a 120mm AIO from Deep Cool Maelstrom 120T Gamer Storm with Push/Pull = 2 fans. Well on heavy torture under Aida 64 all 4 tests, except harddisks and GPUs average temps are 75c and spikes are going to some 84c, those random calculations from the AVX / FPU test, although without the FPU only CPU, CACHE and MEMORY temps are very good to some 60-65c range and when I play Battlefield V temps are 60-70c depends, I have paired the 3600 with a GTX 1060 6GB, 2x 8GB 3200MHz Hyper Predator, SSDs and I do play on Medium Settings on 1080p on 75Hz monitor, and I get some descent 100fps on average, and spikes higher of course and with HIGH settings some 85-90fps and Ultra with some 65-80fps. Sorry that I am going with all this but I just wanted to give more info on this ISSUE.
Thank you very much, everyone's help is much appreciated, doesn't matter whether there is accurate information given, Priorityon that is, but I also need opinions too.
The third party software programs you sourced are noted for inaccuracies and misleading readings. You can use your own judgement if you choose to rely on them.
That PSU is not decent. It's more of a firestarter. Also, for the sake of relevance, please list your full system's specs in your thread's body as opposed to the sig space. Sig space specs can and will change as you change your system, which will make this thread irrelevant once that happens and a poor soul finds themselves in the same issue as this thread.
Reactions: Vana Ivan Pandovski
System specs as you stated
psu Cooler Master B Series 600W 85% Efficiency
mb asrock b450m pro4
cpu ryzen 3600 @ 4.2ghz
ram 2x 8GB 3200mhz cl16 hyperx predator
gpu Gtx 1060 6gb rog strix
2x ssd's - windows 10 pro
1 hdd
Tell me if more info is needed?!
