[SOLVED] Can you hook up 1 water pump through 2 x 480mm radiators? Along with connecting with 2 GPUs and 1 CPU?
SeriousGaming101
330
Hello all,
This is my PC tower:
https://www.newegg.com/white-therma...er 900&cm_re=tower_900-_-11-133-327-_-Product
The back of the tower can fit 2 480mm radiators. I plan on buying 2 of these (also, I want to add push/pull fans to each radiator for a total of 16 fans):
https://www.newegg.com/p/2YM-000S-003J8?Description=480mm&cm_re=480mm-_-9SIA9AB8DK5565-_-Product
https://www.newegg.com/p/2YM-000S-003K3?Description=480mm&cm_re=480mm-_-9SIA9AB8DK5631-_-Product
So my question is, if I buy just 1 water-pump like this:
https://www.newegg.com/p/22B-003V-0...p&cm_re=water_pump-_-9SIAGT37J15250-_-Product
Will I be able to connect this 1 pump into the 2 480mm radiators and also connect to 2 x RTX 2080 Ti's and my 9900k CPU? All with just 1 pump?
Also, do you think with 960mm of radiator cooling with push/pull config fans, this will keep my GPUs/CPU very very very cool?
Yes. Radiators are some of the least restrictive components, so most of this comes down to the GPU and CPU block and how restrictive you will make the tubing runs.
I would recommend running the GPUs in parallel, not serial.
What GPU and CPU blocks?
