Good morning. I have a Gigabyte B450M DS3H motherboard with a Ryzen 5 3400g. I would like to do undervoltage by offset to lower the temperatures. I have done some testing of this with Ryzen Master with no problem on Windows. The problem I have is that Ryzen Master does not work with virtualization enabled, which I need. Also, most of the time I use linux, so it is not an option either.
The EFI is updated to the latest version. As much as I look at all the options, the option of "Dinamic vcore" does not appear in the M.I.T tab in advanced voltage control, only the voltage of the dram appears.
Does someone know how to solve this problem?
