NZXT vs CM HAF 922: pros, cons, which is better? I personally like the look over the NZXT and I dont mind the few extra bucks as long as it performs just as well. Will all the parts fit into the NZXT?
NZXT: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068&cm_re=NZXT_Phantom_%28Black%29-_-11-146-068-_-Product
CM HAF 922: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
Heres my new build:
LG CD/DVD Burner Black SATA Model GH22NS70 OEM - OEM
Case: COOLER MASTER HAF 922 RC-922M (may change to the NZXT)
HDD: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
GPU: EVGA GTX 570
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130595
PSU: CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276
CPU Cooler: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
CPU+Mobo: I5 2500k + MSI Z68 LGA 1155 Mobo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.674899
Heres my new build:
GPU: EVGA GTX 570
