[SOLVED] Certain websites wont load on wifi, but will with ethernet
kristopheralton
Commendable
Nov 30, 2017
11
Hello all, I just recently fixed my laptop (HDD Replacement), and since fixing it, certain websites wont load on wifi. For instance: Youtube loads and plays videos fine, but the twitch website wont load. Once I plug my ethernet into my laptop, everything loads just fine. Everything loads fine via wifi on all of my other devices. Any thoughts on what could cause this? TIA
An Ethernet connection is faster than a WiFi connection. So the reason for the Twitch website not loading on WiFi connection is quite simple. You are facing network issue. I just tried to load the Twitch website via WiFi connection and I didn't face any issue.
there's a reason that Ethernet is recommended for gaming and streaming over WiFi.
I would recommend you to clear the cache of the browser and check it again .
Try to access that website using WiFi connection during midnight and you won't be facing this issue.
