I am not sure I would attempt to use those together, specifically if it's an AMD system.
If you prefer to use them all together, I would suggest downloading CPU-Z. Take a look at the timings table for one set of the memory and notate them all. Turn off any XMP profile and reboot, verify operation, power down. Remove the old sticks, insert new, boot to see if it will. Utilize CPU-Z again to notate the timings. See if both of them intersect at some speed/latency. If not, it's highly likely that the system will only run them at the lowest common speed and latency, if it boots at all.
It can be quite chancy to utilize even same spec and brand of RAM in separate kits much less to do so with different timings. IME Intel has a better success rate using mismatched kits. Just the same, you likely could end up with more capacity, but significantly slower timings. Given the latency of the newer kit, even in consideration of its faster speed, it could still be a wash with one kit or the other.
