Chkdsk C: /f /r does not solve Disk problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Even after scheduling `Chkdsk C: /f /r /v' in the system startup, the
`errors in the Volume bit map' does not correct. Any other solution to clear
this error?
Thanks for any help & replies.
Brother Brock
Malke
3,000
> clear this error?
> Brother Brock
Have you checked your hard drive's physical health? Test the hard drive
with a diagnostic utility from the mftr. Usually you will download the
file and make a bootable floppy or cd with it. Boot with the media and
do a thorough test. If the drive has physical errors, replace it.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Rock
1,242
> this error?
> Brother Brock
What is telling you there are errors in the volume bitmap? Are you
running into any operating issues?
Rock
MS MVP Windows - Shell/User
