Question Choose a UPS for my rig
Oct 30, 2019
12
Which one should I choose between APC UPS 650av and APC UPS 800av
Mobo: Gigabyte H310M H 2.0
Cpu: Intel i5-9400F 6 core 2.9 Ghz
Gpu: Palit gtx 1050ti 4gb ddr5
Memory: 2 Adata 4gb ddr4 2666 Mhz
Storage: 1tb Western Digital Blue
Psu: Deepcool DE-500 v2
Case: Deepcool Smarter
Monitor: Nvision ip24v1 24” and 24 watts
Thank you for the suggestion. I’ll only connect the system unit and the monitor.
Usually you pick an UPS based on your PSU, the "general" rule says that you need to have in mind number of connections (cables), how much devices do you want to keep online in case of energy fail and how much time.
The easy way is: PSU Wattagex1.6= UPS VA
In this case: 500W*1.6=800VA
That gives you the enough power to keep the rig alive for good minutes while the energy restore or you turn off the rig.
In my case I have a 12OOW PSU but my rig does not use all that, my real use is around 600-700W and I have a 1500VA UPS. With that, I usually have around 10-15 minutes tosave my work and turn off the rig is energy is not restored
