CM Silent Pro 500W is it low?
G
Guest
Guest
Hi all!
I would have a rig and I'm curious if the Cooler Master Silent Pro 500W PSU is enough or not?
CPU: Phenom II X6 1055T
GPU: Gigabyte GTX460 768MB
RAM: 4GB 1333MHz DDR3
HDD: 1TB Green Caviar
And a CM 690 II Adv. case + a DVD+RW.
Don't plan to overclock it (yet).
Thanks in advance!
shovenose
i would not recommend that psu. if you have enough money for those components, youve got a little bit more to send on a quality. i would suggest a 600w+ psu good quality from brands like antec, seasonic, corsair, pc power+cooling, etc...
