Hi Dusty_Roses, the HP DL516A is a docking station for HP/Compaq, a rather expensive workaround for a broken dc-in connector on the mainboard, as the base uses the docking port for providing power to the mainboard. The all-in-one media cable does that too, for a lot less $$.
If your problem with the jack is keeping you from running off the ac directly, is hard to tell from here.
It won't run on ac, with the battery removed from the laptop?
Are those adapters 120 or 135 Watt models?
HP's view is: "when under warranty, we'll replace the board, when out of warranty, HAHAHAHAHAHAHA) Check out our new line of models!"
(No pun intended, I feel your pain!)
