My computer has been perfect. The last component I added was my x52 kraken AIO. And that was back in December. Nothing was wrong. And then I decided to download MK1 because I've been really wanting to play it. It starting making an ear piercing sound. I thought it was coil whine but everyone I asked said it was WAY to loud to be coil whine and said it was more likely a dying HDD. I took out my HDD and my AIO and it continued to make the sound. I was told to, undervolt my GPU and to enable, "Acoustic Sound" in bios for the motherboard. I haven't tried either, but I'm really worried it's my GPU. It's none of my case fans or the gpu fans. I turned them off and checked all of them. The sound will randomly turn on even when my computer is idle. But when I start my computer I was able to do work for 8 hours without it doing it until I turned on MK1. But after I closed it the problem persist. It can go from 2 seconds to like 30 seconds at a time. It sounds like a really loud zipline. I have a Asus B550, Ryzen 7 5800x3D, EVGA 2080 ti, and a EVGA 850w Gold. I also have 16gb of ddr4 ram, 3600mhz. BTW, my pc works completely fine and the temps stay the same during idle and during playing MK1
