Question Connecting Front Panel
I don't get why people are trying to transplant their prebuilt system's innards into a new case. The front panel connector is proprietary to the platform and to also add, it's just driving your return on investments towards negative(a loss) when transplanting innards from a prebuilt to an aftermarket chassis.
Regardless, you can refer to this video;
View: https://youtu.be/3qOmhk6gVik?t=1199
I'd leave that ARGB/RGB connector out of the topic.
Reactions: cfranco82
thank you very much for the response and the video! Why I went this route!? It all started with a Video Card, then a Power Supply, then a New Case… and probably will have to end up buying a new PC :/
Any recommendation for the VDG connector? Do I even have to lug it? If only controls the lights… I don’t really need it.
