Connecting multiple external hard drives to a usb hub
sallyayne
Hello, Can I connect 2 external hard drives and a card reader to a usb hub and if so please specify the specs I should look for. Thank you.
sallyayne
Oh yes, I understand and certainly know that it is doable, but what I was looking for: would the power of a usb hub suffice for a couple of external hard drives. But I do thank you for your answer.
sallyayne
I think you mean first answer these questions?
I will connect hub to desktop
I will use usb hub with external power adapter
Thanks for your time.
profkefah
1,100
78
sorry for the mistakes
because im answering posting in many thread in same time
about your thread
when u connect the hub to usb connect it to rear usb ports
and about the hub with external power adapter
you made the right choice man
