peace be upon you <3
i bought DeepCool GAMMAXX GTE V2 Air Cooler
i installed it easily but didn't figure out how to connect the RGB connecter because it seems that my motherboard doesn't have RGB pins
As above. That Controller (and other similar) can operate completely without any mobo lighting header (although it has an option for connecting to such a header if you have one). In your case, OP, you use a cable included with it to connect to a mobo USB2 header. Then you download and install Arctic's software utility RGB Master. Use that to configure the Controller your way.
