Question Constant lag spikes and extreme ping when playing Rust ?
ProdigySZN
12
I have 7,000 on pc rust. As of 3 days ago I am no longer able to play because every server i join on I have outrageous ping despite being on ethernet with insanely good speeds. I have deleted and re installed rust. reset my dns, ip address, changed my dns server, made rust run high priority on task manager, changed in game settings, and a few other things that im probably leaving out. Below is a video of what is happening along with my internet speeds.
Ive tried everything i can think of and cant find anything with a good answer anywhere on the web. If someone can help me out I owe them big time. Thank you for your time.
What is meant by "7,000"? Something seems missing?
Update your post to include full system hardware specs and OS information.
Make and model router (or modem/router if combined)?
Have you tried another known working (at speed) Ethernet cable?
On your computer run "ipconfig /all" (without quotes) via the Command Prompt.
Copy and paste the full results in your next post.
sorry, meant to put 7000 hours. i have 7000 hrs and this has never happened was suppose to be what it said
i7 8700 @3.20ghz
32 gb ram @3600 mhz
ASRock z390 phantom gaming 4
RTX 2060
and rust is installed on a samsung 970 EVO plus 1tb
windows 10 OS
Router is a nighthawk axe7800 and modem is the one i got from my isp. i have fiber and have tried wifi and lan and same issue on both. i also have a second pc im currently in the process of selling and have tried rust on there too and same issue.
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-BF12254
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Unknown adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : ExpressVPN TUN Driver
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Intel(R) Ethernet Connection (7) I219-V
Physical Address. . . . . . . . . : 70-85-C2-C0-A2-85
DHCP Enabled. . . . . . . . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::856e:4656:1357:64e7%16(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.6(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, August 2, 2024 7:21:06 PM
Lease Expires . . . . . . . . . . : Saturday, August 3, 2024 9:06:21 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 527467970
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-A6-20-3D-70-85-C2-C0-A2-85
DNS Servers . . . . . . . . . . . : 8.8.8.8
8.8.4.4
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : ExpressVPN TAP Adapter
Physical Address. . . . . . . . . : 00-FF-15-16-44-04
Wireless LAN adapter Local Area Connection* 8:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 52-3E-AA-BB-7C-7E
Wireless LAN adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 50-3E-AA-BB-7C-7E
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : TP-Link Wireless N PCI Express Adapter
Suggestions:
1) Try another known working (no lags or spikes) Ethernet cable
2) Increase the lease time.
3) Disable IPv6.
4) Run and post the results of ping, tracert, and pathping. Target Google at 8.8.8.8
Suggestions:
3) Disable IPv6.
Ping statistics for 8.8.8.8:
Packets: Sent = 50, Received = 48, Lost = 2 (4% loss),
Approximate round trip times in milli-seconds:
Minimum = 25ms, Maximum = 34ms, Average = 26ms
Tracing route to dns.google [8.8.8.8]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 14 ms 8 ms 2 ms 100.126.112.1
3 3 ms 3 ms 2 ms 100.67.100.13
4 2 ms 2 ms 3 ms 100.67.100.14
5 3 ms 2 ms 3 ms 100.67.100.17
6 4 ms 4 ms 4 ms 100.67.0.49
7 4 ms 3 ms 4 ms 100.67.1.106
8 4 ms 3 ms 4 ms 100.67.0.5
9 * * * Request timed out.
10 31 ms 28 ms 26 ms 64-233-151-147.ritternet.com [64.233.151.147]
11 27 ms 29 ms * 108.170.231.44
12 28 ms 26 ms 25 ms 142.250.62.203
13 31 ms 28 ms 27 ms dns.google [8.8.8.8]
Trace complete.
0 DESKTOP-BF12254 [192.168.1.6]
1 192.168.1.1
2 100.126.112.1
3 100.67.100.13
4 100.67.100.14
5 100.67.100.17
6 100.67.0.49
7 100.67.1.106
8 100.67.0.5
9 * pm3-28-68.ritternet.com [64.233.131.68]
10 64-233-151-147.ritternet.com [64.233.151.147]
11 108.170.231.44
12 142.250.62.203
13 dns.google [8.8.8.8]
Computing statistics for 325 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0/ 100 = 0% |
1 0ms 0/ 100 = 0% 0/ 100 = 0% 192.168.1.1
3/ 100 = 3% |
2 3ms 4/ 100 = 4% 1/ 100 = 1% 100.126.112.1
0/ 100 = 0% |
3 3ms 5/ 100 = 5% 2/ 100 = 2% 100.67.100.13
0/ 100 = 0% |
4 17ms 4/ 100 = 4% 1/ 100 = 1% 100.67.100.14
0/ 100 = 0% |
5 3ms 4/ 100 = 4% 1/ 100 = 1% 100.67.100.17
0/ 100 = 0% |
6 --- 100/ 100 =100% 97/ 100 = 97% 100.67.0.49
0/ 100 = 0% |
7 --- 100/ 100 =100% 97/ 100 = 97% 100.67.1.106
0/ 100 = 0% |
8 --- 100/ 100 =100% 97/ 100 = 97% 100.67.0.5
0/ 100 = 0% |
9 20ms 4/ 100 = 4% 1/ 100 = 1% pm3-28-68.ritternet.com [64.233.131.68]
0/ 100 = 0% |
10 39ms 4/ 100 = 4% 1/ 100 = 1% 64-233-151-147.ritternet.com [64.233.151.147]
0/ 100 = 0% |
11 27ms 5/ 100 = 5% 2/ 100 = 2% 108.170.231.44
0/ 100 = 0% |
12 27ms 4/ 100 = 4% 1/ 100 = 1% 142.250.62.203
0/ 100 = 0% |
13 27ms 3/ 100 = 3% 0/ 100 = 0% dns.google [8.8.8.8]
Trace complete.
couldnt figure out how to increase the lease time but did everything else
Lease time is changed via the router's configuration screens.
Who has admin rights to the router? You will need help from that person.
Make and model modem?
pathping:
The results are not what I would expect......
Are you in some environment such as an apartment building, dorm, hotel, or office spaces where internet service is being provided?
pathping:
No i live in a house and have a fiber cable. I have admin rights to the router. the modem is some type of DZS dont know exact model got it from my ISP. The only conclusion i can come to is my packet loss since i only lag on rust and its a high intensity game.
