[SOLVED] Cooler for i7-9700k
The Gammaxx 400 is an old design cooler than even today is probing that still up to the task in many situations.
But I will still try to go something with more metal for the 9700K. The dark Rock 4 has a bigger and heavier heatsink and a bigger fan than the Gammaxx 400, so its a nice choice.
If you can't spend that much money the Gammaxx 400 may be your solution.
So you are not overclocking, just letting intel Turbo Boost do its thing?
Im asking you cause one thing is a cooler for stock settings and another thing is a cooler for overclocking.
If you wana know the best cooler all around, the mighty https://noctua.at/en/nh-d15 or the black one: https://noctua.at/en/nh-d15-chromax-black?___from_store=en.
Keep in mind that this "big" cooler wont fit on any case and you need to make sure it has enough RAM clearance. Noctua has a link for motherboard compatibility: https://noctua.at/en/support/compatibility-lists/mainboard.
Other than that there are lots of brands and models and also theres AIO water cooling.
You need to give us more info, like case brand and model, what do you prefer water or air, overcloking or not, etc.?
Cheers
Cheers
i am going to be using the p400a digital edition : http://www.phanteks.com/Eclipse-P400A.html
I just want to turbo boost to 4.2-4.9ghz on 60-70 degrees.
I prefer air cooling because they are cheaper and more reliable.
The nh-15d is great but is too big.
well around 150 bgn aka 85 usd and out of these four i am thinking between dark rock 4 or the nh-u12s
I am torn between The Arctic 34 Esports Duo or the bequiet!Dark rock 4
,but i dont know what temps the arctic 34 esports duo will get with turbo boost on
The first one is a budget opiton and the bequiet! one for the high end option
Arctic Freezer 34 Esports Duo is another great solution that I normally suggest, and its rated for around the same TDP of the DR4.
I think that because of the two fans (in push - pull configuration), if the air can go from front to back without issues inside your case, it will probably equal or beat the thermal performance of the beQuiet one.
The main thing of the budget ones, is that the coat may scratch easily, and instead of taking care of 1 fan, you have to take care of 2.
Still the Arctic should be more than enough too.
Reactions: Thebro40
If you go for a bigger heavier cooler, be Aware that if you move your computer frequently, You can snap the mobo by setting it down a little less than gently. especially if its a car ride or something. Just be careful with that.
Yeah i will be carefull with it but the arctic 34 esports duo isnt that big right?
