Hi all,
I’ve recently put together a new build and I noticed on the bios page that the radiator fans for my ML240R were not being detected. I tried to do some testing like plugging the pump into CPU OPT. The pump was detected and could be configured, so I moved the radiator fans from CPU FAN to CPU OPT, and they were still not detected. This to me ruled out the mobo being the issue.
I’ve now connected the pump to SYS FAN 5/PUMP which is where I believe it should go as I can use the bios to set certain pump settings but my radiator fans while running show no stats.
A little note, when I connected my pump to CPU opt and my fans to CPU, whatever change I made to CPU opt affected the radiator fans too. Weird I know. I wonder if anyone has an idea to the issue.
Also a note, the coolermaster RGB controller only picks up that I have relevant hardware when the pump is plugged to SYS pump but not when it’s in CPU OPT (though the mobo picks it up fine)
Below is my system:
Gigabyte Aorus Ultra Z390
Intel i9900k not overclocked
Corsair vengeance DDR4 32GB (8x4)
850W Corsair Gold PSU
Nvidia 1080ti
Deepcool ARK SE case
Below is my system:
Nvidia 1080ti
