The Corsair SP140 RGB Elite Fans that were included with my Corsair 7000x do not light up right away when I power on my computer. The case fans lights turn on 2 seconds after I press the power button. Is this normal?
I use ICUE and have the rainbow preset for all the rgb ports for the fans and still there is two second delay for the RGB lights to come on immediately after the PC is powered on. Do you think this deliberate?do you use Icue?
If so, have a look at a setting called Hardware lighting under the lights/node, that is the hardware profile. It runs when windows isn't started yet
its restricted to color choices or simple patterns at startup, lighting effects are the lights you get inside windows.
