[SOLVED] Corsair, Evga or Be Quiet! PSU for entry-level PC ?
Jan 21, 2021
i´ve been looking to get a 80 plus bronze Psu for quiet a while now, current one is a Evga w1 600w, my understading is that that is kinda overkill on the watts side for my build also im tired of ketchup and mustard cables
i´ve been checking:
EVGA 500 BQ
be quiet! 500W SYSTEM POWER U9
Corsair CV Series CV650
and i wanted to know your experience with these brands and particular series of psu, any comment helps!
thanks in advance.
all are tier c on the psu tier list... i think.
My build:
Asus a-prime b450m
Amd R5 2600
RX 580 (though i wanna upgrade to RX 5600 xt in the future).
EVGA W1 600w.
Those three are about equal. You don't really need more than 500 W with that configuration. You might be missing some good deals on your country, if you can, provide us with your budget and your online local store for reference then maybe we can find a much better deal for you.
