Question Corsair H60 sata power cable & 650W EVGA SUPERNOVA 650GM
May 26, 2021
4
Like what cable or connector should I get.
on this AIO I plugged all the 3 pin and 4 pin to my MB
now the only problem is SATA POWER CABLE.
MY PSU is 650W EVGA SUPERNOVA 650GM.
Thank you!
Karadjgne
Ambassador
That doesn't make sense, sorry. There's only 1 plug on an H60 and that's a 4pin that goes to the cpu_fan header. The 3pin from the fan goes to the sys_fan header. There isn't a Sata power connector nor a USB on the H60 that I've ever seen. You'd need to have a H100i series with RGB and pump powered fans with USB iCue connection to have need of a Sata power connector.
