G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have two identical A7N8X systems, except that for one
I accidentally ordered a different grade of Corsair XMS
PC3200 memory. In one machine I have stuff that runs
at 200Mhz at 6-3-3-2, manually set since SPD is wrong.
In the other, I have a lower grade which runs at 8-3-3-3
at 200Mhz (and will fail if set lower). Both have the same
processor (3200+).
The weird thing is that these two systems perform
identically! In fact, I was at first getting lower numbers
on the 6-3-3-2 machine until I found that it had a debug
ethernet driver that was costing me a couple percent of
the CPU.
The symmetry in performance holds for all benchmarks,
including SiSoft Sandra memory bandwidth. Both get
2950/2750. So why pay extra for the lower latency
stuff if they perform the same? I saved about $50 due
to this apparently fortunate accident.
Maybe I am doing something wrong with the faster
memory, but I'm at a loss to figure it out. Is anyone
getting more than 2950 for the bandwidth with the
PC3200C2 at 200Mhz?
Alan
processor (3200+).
the CPU.
PC3200C2 at 200Mhz?
Alan
